Hardware Thread, Two problems same printer HP2605dn in Technical; Hi Peps
Have two problem with the same model printer a HP2605dn please help!
First is that the print quality ...
17th September 2009, 03:51 PM #1 Two problems same printer HP2605dn
Hi Peps
First is that the print quality is very poor there are loads of black line running acrss the page. I have changed all the toners and run a cleanning job on this printer with no change. Could it be the tranfer belt coming to the end of its life time?
Second problem I have with a different 2605dn is that it will not attach to my network (has done in the past). I have set the IP address manual and it holds it but then you can not ping it and it does not apear in DCHP. If you try and set the IP address by the automatic option it just hangs and when you print a test page under TCP/IP it just says configuring. The lights on the network card are flashing like it attached to the network but it clearly is not.
Any ideas peps
Thanks in advanced
Training Needed
IDG Tech News
By jason2234 in forum Windows
Last Post: 3rd April 2009, 02:14 PM
By HCHSAdmin in forum Hardware
Last Post: 10th March 2009, 03:04 PM
By SimpleSi in forum Hardware
Last Post: 30th January 2009, 12:01 PM
By ltunstall in forum Thin Client and Virtual Machines
Last Post: 12th March 2008, 10:44 AM
By Ric_ in forum Hardware
Last Post: 6th September 2005, 12:57 AM
- You may not post replies
- You may not edit your posts
Forum Rules
