Results 1 to 14 of 14
Hardware Thread, Battery replacement Plexus UPS in Technical; We bought 2 Plexus UPS-1200MV from Ebuyer about 18 months ago. Both appear to have died at the same time. ...
    Jul 2009
    1
    We bought 2 Plexus UPS-1200MV from Ebuyer about 18 months ago. Both appear to have died at the same time. Disappointing! Batteries have a bulge so guess they overheated or had a fault.
    Would like to replace battery if cost effective but dont know where to get them. Ebuyer not very helpful but tell me the model is also known as PLEX-020. Tenda owns Plexus.
    any ideas?... UK based!
    Michael's Avatar
    Dec 2005
    Birmingham
    242
    346
    This is why I use APC. Their products are easily the best and buying replacement batteries are easy to source.
    Rather worringly Google Shopping comes up with zero results for Plexus UPS-1200MV. Have you tried the manufacturer website?
    Jul 2009
    1
    i have to agree cheap may not have been a good policy!
    this is the same ups:
    Plexus MV 1200VA UPS
    so far i could not find it at plexus or tenda
    Michael's Avatar
    Dec 2005
    Birmingham
    242
    346
    At £37.99 I would just throw them out to be properly recycled and by some decent APC kit.
    Jul 2009
    1
    i would.. if i could afford it!
  6. #6
    Michael's Avatar
    Dec 2005
    Birmingham
    242
    346
    I wonder because it's so cheap whether you can even replace the battery at all? You could just buy another UPS at £37.99 I suppose.
  7. #7
    LeMarchand's Avatar
    Jan 2008
    The deepest pits of hell
    327
    223
    Breaths sigh of relief that I asked for (and took advice from) here before buying one of those Plexus units!
  8. #8
    maniac's Avatar
    Feb 2007
    Kent
    210
    145
    Check the batteries carefully against the website below. I'll place money that they match up to one of the yuasa standards, probably in the NP range - they nearly always do. APC ones certainly do, and you can save a shedload by buying them directly and not through APC, and they are exactly the same battery!
    NP Range
    Mike.
  9. 2 Thanks to maniac:
    Dav3y (25th July 2009), tim441 (25th July 2009)
  10. #9
    dirtydog's Avatar
    Sep 2008
    47
    24
    I use MDS Battery they have been excellent so far.
  11. #10
    Jul 2009
    1
    thanks for the pointers. Yuasa do seem to have the right ones... i think it needs 2 in each ups. The battery shop told me:
    looking at the spec sheet it looks like the batteries are NP7-12 or NP7-12L this are both available on our web site NP7-12 Yuasa 12v 7Ah Lead Acid Battery or NP7-12L Yuasa 12v 7Ah Lead Acid Battery
    the batteries are both the same size thay just have differant size terminals.
    Please check sizes before ordering.
    Also it sounds like the batteries are being over charged.
    The Battery Shop (UK) Ltd
    20 Orbit Centre
    Ashworth Road
    Bridgemead
    Swindon
    Wiltshire
    SN5 7YG
    Tel: 01793 421509
    Fax: 01793 432010
    The Battery Shop
    FREEPHONE 0800 783 4396
  12. Thanks to tim441 from:
  13. #11
    Jun 2009
    Kent
    8
    12
    Quote Originally Posted by tim441 View Post
    I've had this happen with batteries in 2 APC units one summer so you're not alone. They blew up like balloons and were near impossible to remove from the units.
    I take it these are in a cool room and the temperature stays fairly low? Anything much over 30deg will shorten the life of the batteries whichever make of UPS you have. Temperature was the prime cause of the failure i had some years ago and that was immediately prior to having aircon fitted to our server room and certainly helped my cause in getting this fitted in the first place.
    Thanks for the tips on those other places to get batteries too guys as i normaly use CPC for my UPS batteries and as mine are now due for replacement due to age i'll most probably be buying them direct or from the other place posted instead as pricing looks slightly better.
  14. #12
    Jul 2009
    Shropshire
    2
    12
    it does indeed, so probably not worth replacing the baterries if there bieng over charged they will just swell and split the cells again. Also dangerous as they can release hydrogen (very explosive) gas (if there lead acid).
    18 months dosnt seem very long for a UPS, i would complain to the manufacturer, they might offer u a replacement as a courtesy
  15. #13
    May 2010
    UK
    I've always found these guys very helpful
    The Safety Centre
  16. #14
    May 2010
    UK
    This is the battery is used
    NP7-12
  1. UPS Battery ....
    By Little-Miss in forum Learning Network Manager
    Last Post: 5th November 2009, 11:57 AM
  2. Change UPS Battery
    By FN-GM in forum Hardware
    Last Post: 28th April 2009, 10:14 AM
  3. Plexus UPS
    By LeMarchand in forum Hardware
    Last Post: 9th January 2009, 12:09 PM
  4. APC Replacement Battery
    By Michael in forum Hardware
    Last Post: 6th October 2008, 10:49 AM
  5. UPS Battery pack: Homebrew replacement?
    By rhyds in forum Hardware
    Last Post: 28th August 2008, 12:59 AM
