Results 1 to 4 of 4
Hardware Thread, Keep losing wireless connection. in Technical; My HP6715B laptop at home is connected to a Belkin router. Recently, the wireless connection has been dropping out if ...
    Sep 2007
    UK
    781
    292
    My HP6715B laptop at home is connected to a Belkin router. Recently, the wireless connection has been dropping out if the computer isn't used for a half hour or so. If I run the diagnostics it says the router is shown as "Hidden". Rebooting it gets it going again.
  2. IDG Tech News
  3. #2
    mac_shinobi's Avatar
    Aug 2005
    1,085
    209
    the belkin router is the problem - you could try a different channel for the wireless but not sure that will help much. That or a firmware update on the router ?
    Also try it with no encryption on the router and see if that helps if it does then maybe try wep and if thats fine then go back to WPA or w/e you are using.
  4. Thanks to mac_shinobi from:
    laserblazer (22nd June 2009)
  5. #3
    mullet_man's Avatar
    Oct 2005
    Oldham
    32
    22
    I had trouble with our new o2 box, changed channel and encryption and it seems much more stable.
  6. #4
    Mar 2009
    Leeds
    134
    149
    its not an intel 5100 wireless card is it as they are utter pap
  1. Wireless policy losing settings
    By Bobo in forum Windows
    Last Post: 22nd October 2009, 09:07 AM
  2. Vista losing connection
    By rh91uk in forum Windows Vista
    Last Post: 17th November 2008, 05:25 PM
  3. Wireless connection to server
    By chalkwellstu in forum Windows
    Last Post: 12th September 2008, 01:08 PM
  4. Wireless Connection
    By marvin in forum Windows
    Last Post: 23rd April 2008, 07:12 PM
  5. Wireless connection keeps disconnecting
    By callumtuckey in forum Networks
    Last Post: 27th June 2007, 07:32 AM
