Hardware Thread, Smart Speakers USB problem in Technical; Sorry if this has been covered before, but I can't find an entry...
New smartboard and speakers fitted. Connection from ...
11th May 2009, 12:36 PM #1 Smart Speakers USB problem
New smartboard and speakers fitted. Connection from spreakers direct to USB port. Plays sound perfectly well for a couple of hours then nothing. The USB port on the computer dies.
The installer will, of course, replace if faulty but says he hasn't had the issue before.
Any ideas?
IDG Tech News
11th May 2009, 12:43 PM #2
Originally Posted by
phily
Any ideas?
not the little amp overheating or something?
11th May 2009, 12:48 PM #3
- Rep Power
- 0
Does the speakers stop working after the pc goes into power save mode?
11th May 2009, 01:01 PM #4
- Rep Power
- 8
i've got the same problem, last week on monday i was called to say the sound didn't work, when i started the pc without the usb in them and then added the usb it was detected and worked, but then on friday it had stopped again.
11th May 2009, 01:02 PM #5 Maybe been covered before but is the power saving mode enabled on the USB hub itself (system properties -> hardware -> properties.
11th May 2009, 01:22 PM #6 Power save mode is not an issue. The port goes down and stays down. I plugged in a USB optical mouse into the 2 ports that didn't work for sound and it wouldn't power up. As soon as the speakers ae plugged into another USB port, the computer detects them and starts to work. But I'm going to run out of working ports!
I've had issues before where firewire has 'burnt out' following prolonged use, I wonder if there could be a similar issue but I suspect not.
11th May 2009, 10:06 PM #7 Perhaps try a main powered USB Hub see if that works?
By CM786 in forum Educational Software
Last Post: 24th March 2010, 02:21 PM
By JAW$ in forum Windows Server 2000/2003
Last Post: 13th December 2009, 02:24 PM
By firefighting in forum Hardware
Last Post: 18th November 2008, 12:53 PM
Last Post: 16th October 2007, 02:22 PM
- You may not post replies
- You may not edit your posts
Forum Rules
