Results 1 to 4 of 4
Hardware Thread, To enbale or not to enable flow control? that's the question in Technical; we have a HP4108gl switch. As i have a bit more time on my hands i thought i would look ...
    projector1's Avatar
    Nov 2005
    58
    14
    we have a HP4108gl switch. As i have a bit more time on my hands i thought i would look at the configurations of the key hardware devices. I have noticed that some ports are set to enable flow control and some not
    What are the benefits of flow control and is it worth enabling or not.
    cheers
  2. IDG Tech News
  3. #2
    Nov 2005
    Middlesbrough
    Re: To enbale or not to enable flow control? that's the ques
    Enable!
    Flow control manages the rate that information is sent between two devices, if one device starts sending packets at a rate the reciveing device can't handle due to load or whatever then you'll start getting network congestion.
  4. #3
    projector1's Avatar
    Nov 2005
    58
    14
    Re: To enbale or not to enable flow control? that's the question
    thanks indie, i have just been given the same advice by a engineer who happened to be onsite today.
    Many thanks
  5. #4
    Mar 2007
    Devon
    143
    20
    I know is a really old thread so sorry for bring it back but thought better than starting a new thread...
    I'm in the process of upgrading all our main switchs to HP Procurve stuff, 2650's and a 5400zl do i want to turn flow control on all ports or just certain ones?
  1. Enable/Disable workstation internet access from shortcut
    By the_mighty_boosh in forum Netware
    Last Post: 28th January 2011, 10:34 AM
  2. Easy way to enable dialin access in AD
    By localzuk in forum Windows
    Last Post: 26th October 2007, 11:08 AM
  3. How do you enable pop3 on exchange 2000?
    By nicholab in forum Windows
    Last Post: 16th July 2007, 11:40 AM
  4. Enable Search In Windows Explorer
    By DaveP in forum How do you do....it?
    Last Post: 22nd March 2007, 02:46 PM
