Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Hardware Thread, Power in suite keeps tripping! in Technical; Hope someone can help with this as its driving me mad. Most mornings when I come in the power in ...
    titch's Avatar
    Feb 2007
    102
    17
    Most mornings when I come in the power in our ict suite has tripped, which means I have to manually turn pcs on (instead of wol) which isnt to bad..but on mornings when Im not there I dont like the idea of other people having too turn the power back on via the switch box as if all the switches are turned on too quickly the power in the main switch cupboard will also trip.
    Now a little background, Spiradically some of the psu have been dyeing in the suite, Im not sure if this is the cause or the effect of the constant tripping either way I know some of the psu's are on there way out although I have replaced 3/4 of them now.
    Is there going to be a simple way to diagnose where the fault is coming from, and what time maybe the power has tripped to see if that has any relation. The strange thing is the power trips more in the night (when no pcs are switched on) than in the day when they are all on. The rccb says 80a 30ma on. And we have 34 pcs and monitors running from it. Our sparky (who I trust) has told us the fualt isnt with the switch but some of the units we are using, but is proving a mistery to me which ones are causing the fault.
    If anyone has any ideas they would be greatly appreciated as it is very frustrating!
    Heres a picture of the switch box if it helps anyone, each of the switches represents a row of pcs then the one that says pr1 is the projector.
    plexer's Avatar
    Dec 2005
    Norfolk
    756
    438
    How many pc's in each row being feed by each of those rings?
    titch's Avatar
    Feb 2007
    102
    17
    5/6 depending on row.
    Cheers for quick reply
    plexer's Avatar
    Dec 2005
    Norfolk
    756
    438
    It could be the psu's in those units we have 6 - 8 I'd guess on a ring in the main suite and don't have an issue but I have seen it before.
    Is there anything your sparky can do to test the pc's at all?
    FN-GM's Avatar
    Jun 2007
    UK
    906
    12
    468
    If you use WOL its probably not helping that all computers are going on at the same time. You could try staggering them like 8 at a time or something.
  6. #6
    plexer's Avatar
    Dec 2005
    Norfolk
    756
    438
    Marc's Technical Pages: Power Quality Symptoms and Solutions - Leakage Current in Technology bit of nice reading.
    Are the monitors switched off at night?
  7. #7
    Jamman960's Avatar
    Sep 2007
    London/Kent
    190
    48
    Is it individual rows that trip? and is it the same rows that trip each time?
    It may be worth ensuring the monitors aren't on standby overnight, I've known monitors to cause trips every now and then.
  8. #8
    Little-Miss's Avatar
    Oct 2007
    London
    2,416
    2
    552
    Last time i had a classroom that kept tripping, it turned out to be a dodgy monitor! I only worked it out when the monitor finally cooked itself, was replaced and it never happened again.....
  9. #9
    p858snake's Avatar
    Dec 2008
    Queensland
    37
    2
    52
    Has every electrical device (monitors/towers/printers/network switches/vga split boxes ect) been tested and tagged?
  10. #10
    Cools's Avatar
    Jan 2009
    Bedfordshire
    24
    26
    i would up the trips to a higher amp trip and the RCD to, it will stop it. but its not the best fix.
    its the CRTz that do it,thats if you have any?
    Both my ICT rooms have 3 trips 30mA and both rooms have 32 PCs all WOL.
    never triped once.
  11. #11
    titch's Avatar
    Feb 2007
    102
    17
    Funny thing is has never tripped when waking all the computers at once.
    A light bit of reading...think I got the jist of it. I have tried turning monitors off (at button not power switch) but doesnt seem to make much difference. I take it its better to have them off then?
    Well the there is only 1 rcd so whatever trips take the lot with it. So what I do is turn all rings off, then rcd on, then one at a time switch the individual rings back on. I guess in an ideal world each ring would have its own rcd?
    Any way of diagnosing this before it frys you think?
    Cheers for all the help.....off topic and sure its asy but how do you qoute more than one person at a time?
    Thanks Rich
  12. #12
    Arcath's Avatar
    Feb 2009
    Lancashire
    103
    74
    Quote Originally Posted by titch View Post
    << Multi quote, click on all the posts you want to quote than click "Post Reply"
    I dont think theres any way of diagnosing a dodgey monitor (other than funny colours/lines) if its causing power issues your sparky might be able to test it, but even then it might only cause an electrical fault under certain circumstances
  13. Thanks to Arcath from:
    titch (22nd April 2009)
  14. #13
    robk's Avatar
    Nov 2005
    Ashbourne
    187
    1
    49
    Looking at that board, all of the leakage current for all of the machines is being measured by that one RCD. This lead to nothing but problems with us.
    Leaking CRT monitors, power supplies and simple filtered sockets all add up to a large background level of earth leakage. Anything slightly off will push it over the edge.
    We ended up fitting RCDs per bank of sockets, but its not a cheap fix.
    Problem is, turning off banks of machines will drop the "background" level, and hide the issue!
    Try unplugging a system (at the wall) one at a time, see if it stays on over night?
    RobK
  15. #14
    Gerry's Avatar
    Jun 2007
    North Wales
    60
    25
    Turn everything off at the plug except 1/2 the monitors. If it trips you know which 1/2 is causing the problem. Repeat until you're left with the faulty monitor(s).
  16. #15
    ICT_GUY's Avatar
    Feb 2007
    Weymouth
    689
    106
    We had similar probs in our new suite, we had the trip switches changed to be less sensitive.
  1. New Suite.
    By ICT_GUY in forum Hardware
    Last Post: 24th February 2009, 01:23 PM
  2. Media Suite
    By Sunderwood in forum How do you do....it?
    Last Post: 12th March 2008, 07:31 PM
  3. Replies: 14
    Last Post: 31st January 2008, 02:13 PM
  4. Laptop trollys tripping power.
    By maniac in forum Hardware
    Last Post: 15th March 2007, 01:20 PM
  5. New PC Suite
    By steelrazor in forum Hardware
    Last Post: 3rd December 2006, 02:38 AM
