Hardware Thread, strange hardware problem in Technical; Originally Posted by Michael
My apologies, I just presumed you were running Windows, but you're infact just using it for ...
7th June 2009, 06:15 PM #16
Michael
My apologies, I just presumed you were running Windows, but you're infact just using it for additional storage. Thinking about it further, have you tried taking the SATA card out and re-seating it? And tried it in another PCI slot (if possible?)
Another way of looking at it, is when you disconnect the drives and boot your system, is the SATA card listed when you look at the equivalent of Device Manager?
Tried it in different pci slots, reseated it a number of times. I even bought a replacement, in case it was damaged somehow (an exact same make/model etc etc) and they both exhibit the same problems.
Ill try a different card/chipset next. And if that doesnt work, then Ill just get a IDE card and some sata to ide converters!
IDG Tech News
17th June 2009, 04:31 PM #17
RabbieBurns
Can anyone recommend a 2 port sata PCI card that doesnt use a Silicone Images chipset?
Also, I found one of these
Would I just plug the sata cable into that, and then that thing into an IDE socket? Whats the white connector for?1
17th June 2009, 09:40 PM #18
RabbieBurns
Its a floppy disk drive power connector to provide power for the converter to function.
18th June 2009, 05:06 AM #19 Oh right, so Id need a PSU that had one of them. Ah well thats that idea out the question then.
Any suggestions on a sata card?
18th June 2009, 06:07 PM #20 You could just use a y cable off a normal power connector:
Belkin Components Disk Drive Power Y Splitter Cable 6 In
Power Supply Adaptor Cable Assembly > Maplin
As to a sata card does it need RAID and what OS specificly does it need to be compatible with?
19th June 2009, 04:00 PM #21 no need for RAID, just an expansion card.
Its a gentoo linux system, and for some reason somethings just not working with the Silicone Image cards, but I don't think its OS related, as the problem lies before the system even boots.
4th July 2009, 12:18 PM #22 Is Promise a brand that will just use another chipset, or is Promise the actual chip? Ive found this one that looks promising:
Promise SATA300 TX4 - storage controller - SATA-300 - PCI / 66 MHz OEM - Ebuyer
Ive used adaptec before with success, and this one looks good
Adaptec Serial ATA II RAID 1420SA - Storage controller (RAID) - 4 Channel PCI-X - SATA-300 low profile - Ebuyer
However it says its low profile, does it exist in normal size?
Cheers!
By denon101 in forum Windows
Last Post: 1st February 2011, 02:35 PM
By adamf in forum Windows Server 2000/2003
Last Post: 20th April 2009, 11:21 PM
By Michael in forum Windows
Last Post: 25th February 2008, 03:05 PM
By Maxell in forum Windows
Last Post: 5th February 2007, 05:01 PM
By richard in forum Windows
Last Post: 21st February 2006, 01:47 PM
- You may not post replies
- You may not edit your posts
Forum Rules
