Results 1 to 10 of 10
Hardware Thread, Latitude D505 (*sigh*) battery problem in Technical; I have a D505 that will not charge the battery and only lasts for 10 mins on battery power. I ...
    witch's Avatar
    Nov 2005
    Dorset
    1,463
    757
    I have tried a known good battery, and also a new one with the same result
    Computer works fine on AC power
    Can I really presume that the charging circuit on the mobo is carked or is there anything else I can do to check?
    I don't relish telling the powers that be that yet another laptop has died so I want to be really sure before I do
    broc's Avatar
    Jan 2006
    England
    104
    150
    I am not sure about D505, but with most D series Latitude notebooks you can normally check by booting into BIOS if they have recognised the charger and are charging the battery.
    witch's Avatar
    Nov 2005
    Dorset
    1,463
    757
    Yes, and it says it is
    But the battery doesn't charge which is why I got a new one
    But it still doesn't!
    SYSMAN_MK's Avatar
    Sep 2005
    490
    429
    Silly question, but you don't say if you have tried a different charger? Also do both batteries charge fine in another laptop?
    maniac's Avatar
    Feb 2007
    Kent
    210
    144
    I hate to say it, but the older Dell laptops are prone to this. I've had no less than 14 D510 laptops die on me since September, all with the same fault as you're describing. The only fix seems to be a new motherboard at a cost of about £100 a unit.
    We are still fixing them in-house until the end of this year, then as they die they will be scrapped in our school.
    Mike.
  6. #6
    witch's Avatar
    Nov 2005
    Dorset
    1,463
    757
    Quote Originally Posted by SYSMAN_MK View Post
    Sorry, yes I have tried another charger and both batteries are fine in another laptop
  7. #7
    powdarrmonkey's Avatar
    Feb 2008
    Alcester, Warwickshire
    412
    182
    We had a duff batch of D505's a couple of year's ago, nearly every one has been a warranty job now. There's a known problem with the charging circuit, just as you say.
  8. #8
    ricki's Avatar
    Jul 2005
    uk
    20
    52
    Hi
    Do you have more than one d505 if you do then put the battery into another and see if it works ok in that. I have had some problems with chargers, batteries and motherboards with regards to charging. I think off the top of my head the d505's were the ones where there was a product recall on some batteries.
    Good Luck
    Richard
  9. #9
    Feb 2008
    412
    182
    There's been a battery recall on just about every Dell battery ever produced..
  10. #10
    nc-
    nc- is offline
    Mar 2009
    14
    12
    we have had the same problems with d505 and d520's.
  1. dell latitude d505 power issues!
    By krisd32 in forum Hardware
    Last Post: 5th May 2009, 03:23 PM
  2. Need a replacement Dell Latitude Battery
    By Little-Miss in forum Recommended Suppliers
    Last Post: 29th January 2009, 04:42 PM
  3. Dell Latitude D820 Battery Issue
    By SYSMAN_MK in forum Hardware
    Last Post: 20th May 2008, 11:05 AM
