Results 1 to 3 of 3
Hardware Thread, HP64 Bit/66Mhz Dual Channel Wide Ultra3 SCSI Adapter problem in Technical; Server is HP ProLiant ML370 In it is a HP64 Bit/66Mhz Dual Channel Wide Ultra3 SCSI Adapter Which now for ...
    mattx's Avatar
    Jan 2007
    1,058
    740
    Which now for some reason won't see my HP Ult 920 tape drive.
    All was working fine until I did a load of 2003 server security fixes, re-booted and BAM - won't see the drive......
    Before I start chucking the server out the window....can anyone help ?
    On one channel I have [ that has THE conflict ]
    PCI bus 1, device 3, function 1
    On the other
    PCI Bus 1, device 3, function 0 - This is working
    If I go into the SCSI setup on bootup - then all I can do is change the ID of the SCSI card - which is pointless.....
    Then If I select the device I can't change the bleeding ID because it comes up No Drive Found or Drive is DR mode.
    What the hell does that mean ?
    I've never experienced such crapness with anything SCSI in my life but this pile of HP shite is starting to annoy me - suggestions anyone ?
    I can't even update the drivers on the card because I have to contact my HP rep to get them..... Yeah thanks HP.....
    Butuz's Avatar
    Feb 2007
    Wales, UK
    211
    63
    You can change the SCSI ID actually on the tape drive usually via a dip switch or jumper.
    Very strange problem. Has the tape drive dissapeared from the SCSi BIOS before you get into windows?
    Butuz
    mattx's Avatar
    Jan 2007
    1,058
    740
    Bleeding stupid HP - you know what it was ?
    I changed the old Ult 1 tape drive months ago and did not remove it from Backup exec, I put the new tape drive on the same SCSI ID and ok, Backup exec did see both drives but it carried on working on the new drive.
    God knows why I after this re-boot [ its been re-booted before ] it decided to get it's knickers in a twist over the SCSI ID - there is nothing else on ID3 [ apart from the old drive and thats not even installed ]
    I changed the ID to ID6 and now it's fine - god knows why it started getting all picky - bleeding daft. And as for the HP SCSI config setup [ from boot ] - what a pile of shite - you can hardly do anything with it apart from change the ID of the actual interface.....
  1. LanSchool 7.2 secure and 'Channel 0'
    By googlemad in forum Network and Classroom Management
    Last Post: 9th October 2008, 10:20 PM
  2. Crystal ICT Channel
    By conehead in forum Educational Software
    Last Post: 14th May 2008, 06:04 PM
  3. Channel 4 ClipBank
    By beeswax in forum Virtual Learning Platforms
    Last Post: 2nd May 2008, 01:25 PM
  4. Mixing HDD and DVD on the same IDE channel.
    By laserblazer in forum Hardware
    Last Post: 24th February 2008, 11:41 AM
  5. Replies: 6
    Last Post: 14th June 2006, 12:31 PM
