Welcome, Register for free! or Login below:
EduGeek.net RSS Feeds Register FAQ Members Social Groups User Map Calendar Search Today's Posts Mark Forums Read
Hardware
Hardware forum sponsored by
HardwareForum Sponsored by SCL Online
For any hardware related issues, recommendations or warnings about awful equipment.
Go Back   EduGeek.net Forums > Technical > Hardware
Reply
LinkBack Thread Tools Search Thread Language
Sponsored Links
Old 16-11-2008, 10:10 PM   #1
RabbieBurns's Avatar
uk scotland
Rep Power: 14 RabbieBurns is a jewel in the roughRabbieBurns is a jewel in the roughRabbieBurns is a jewel in the roughRabbieBurns is a jewel in the rough
Default unknown hardware problem
Im out of ideas now and need some suggestions.
Got a custom built machine that is having some problems of late.
Its got 8 HDs, 4 on the motherboard channels and 4 on a controller card.
All HDS pass all the manufacturers advanced diagnostic tests.
Memtest passes all tests 100%
The problem is, the system will make a CLUNK sound, and then just die. It stays powered on, but everything is dead (video, network etc)
Its definately not OS related as it happens when booted into various OS and even with OS HD unplugged and booted to LiveCD.
Im thinking of ordering a new PSU (current one is 400w not sure if thats too little)
Gonna try a different gfx card but I dont think that is the problem.
I dont think its overheating either.
Im running out of ideas. Any suggestions welcome please.
Old 16-11-2008, 10:29 PM   #2
SYNACK's Avatar
newzealand
Rep Power: 59 SYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant futureSYNACK has a brilliant future
Send a message via MSN to SYNACK
Default
I would test it with a more powerful PSU, it takes a bit of power to ramp hard drives up to speed and eight is quite a few, the clunk is probably the disks doing an emergency park as they run out of power to spin up fully.
Last edited by SYNACK; 16-11-2008 at 10:36 PM.. Reason: wrong component listed, oops
The Following User Says Thank You to SYNACK For This Useful Post:
RabbieBurns (21-11-2008)
Old 16-11-2008, 10:33 PM   #3
uk scotland
Default
THe thing is, itll run for X amount of time before the Clunk, anywhere between 15 mins and 2 days.
Ive just ordered a 600W psu so will test that out when it arrives.
Old 16-11-2008, 10:37 PM   #4
Curt_LFC's Avatar
Rep Power: 0 Curt_LFC is an unknown quantity at this point
Default
400w power supply for 8 disks seems pretty low to me, would definitely try the 600w and see if that fixes the problem
The Following User Says Thank You to Curt_LFC For This Useful Post:
Old 16-11-2008, 10:50 PM   #5
uk scotland
Default
ok thanks, hope thats all it is.
I was convinced there was a dodgy disk in there causing it to trip but spent the whole day deep scanning them all and they all passed the tests.
Old 16-11-2008, 11:08 PM   #6
DarkLight's Avatar
uk uk devon
Rep Power: 0 DarkLight is an unknown quantity at this point
Default
If the computer can be used without all the disks in, remove one and test it again to see if it has the same issue. If it does, continue through with the removal of the next disk and place the previous one back in. I've had a similar issue to this with all the disks, even though they passed all tests, the primary disk decided it would rather make a noise and stop functioning. As soon as I disabled it and removed it from the system the computer was fine again.
Then again, it could also easily be a power issue, or a number of other vital components that aren't easily tested except by replacement.
Old 16-11-2008, 11:36 PM   #7
Jay
Jay's Avatar
uk
Rep Power: 2 Jay is on a distinguished road
Default
Discs dont use much power, compared with things like Graphics Cards and CPU's so I'd say 400 watt ought to be fine. Of course thats only if its 400 watt sustained and not one of these 400w peak on a good day in Feb, when the ambient temp is below 10c, and the year is a prime number types.
(I once ran up a Qtek 550w on a test bed and got less than 300w out of it when maxed out.)
From memory each drive ought to use up to 25w at startup and less in operation. I think the newer SAS ones use much less, as do most 2.5inch.
Old 16-11-2008, 11:45 PM   #8
FN-GM's Avatar
uk
Rep Power: 43 FN-GM is a splendid one to beholdFN-GM is a splendid one to beholdFN-GM is a splendid one to beholdFN-GM is a splendid one to beholdFN-GM is a splendid one to beholdFN-GM is a splendid one to beholdFN-GM is a splendid one to behold
Send a message via Skype™ to FN-GM
Default
How about air flow? it could be that the computer is knocking off because its to hot in the case.
Old 16-11-2008, 11:59 PM   #9
bizzel's Avatar
uk uk durham city
Rep Power: 16 bizzel is just really nicebizzel is just really nicebizzel is just really nicebizzel is just really nicebizzel is just really nice
Send a message via Skype™ to bizzel
Default
If it is the PSU then dying at random intervals sounds possible, especially if those random intervals are at busy times when all the disks are being accessed.
The Following User Says Thank You to bizzel For This Useful Post:
Old 16-11-2008, 11:59 PM   #10
uk scotland
Default
I probably missed an important bit of information: that its been running fine since feb with 7 disks, and started doing this about a month ago. Ive since added a new disk.
Airflow is fine, ive used the rounded IDE cables so theres no ribbon cables, its a big deep rackmount case. Massive fan for the HDs, and an extra fan for the CPU.
Ive got it sitting here with the top off and its def not too hot.
Old 17-11-2008, 12:17 AM   #11
uk scotland
Default
Old 18-11-2008, 04:01 PM   #12
uk scotland
Default
Put in the new 600W PSU this afternoon.
Will see how things go.
Old 19-11-2008, 01:19 AM   #13
uk scotland
Default
Code:
robert@blah ~ $ uptime
 00:13:36 up 11:12,  1 user,  load average: 0.00, 0.00, 0.00
so far so good
Old 19-11-2008, 09:27 AM   #14
jcollings's Avatar
Rep Power: 16 jcollings is a jewel in the roughjcollings is a jewel in the roughjcollings is a jewel in the roughjcollings is a jewel in the rough
Default
I love it - you've invented a kind of hard disk Buckaroo - just keep on adding hard drives until the whole thing kicks back and stops working.
Most excellent
Old 21-11-2008, 12:44 PM   #15
uk scotland
Default
Thanks for the PSU suggestions. Its solid as a rock now
jcollings: Still got space for another 3 disks so will still be adding to it for a while yet
Reply
Register now for FREE and post messages!
Username: Password: Confirm Password: E-Mail: Confirm E-Mail:
Birthday:
Image Verification
  I agree to forum rules
Thread Thread Starter Forum Replies Last Post
Unknown RAM usage. Trenton_Lister Windows Vista 7 30-09-2008 02:28 PM
Help Identifying Those Pesky 'Unknown' Devices DaveP Hardware 6 02-09-2008 08:18 PM
Unknown Messages dryhammer Thin Client and Virtual Machines 2 07-05-2008 08:42 AM
unknown model!? browolf Hardware 5 04-04-2008 01:56 PM
Hardware Problem on a Ripreped PC ChrisH Hardware 3 15-01-2006 08:24 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 ©2008, Crawlability, Inc.
Copyright EduGeek.net
