Welcome, Register for free! or Login below:
EduGeek.net RSS Feeds Register FAQ Members Social Groups User Map Calendar Search Today's Posts Mark Forums Read
Hardware
Hardware forum sponsored by
HardwareForum Sponsored by SCL Online
For any hardware related issues, recommendations or warnings about awful equipment.
Go Back   EduGeek.net Forums > Technical > Hardware
Reply
LinkBack Thread Tools Search Thread Language
Sponsored Links
Old 14-11-2008, 05:48 PM   #1
firefighting's Avatar
uk uk kent
Rep Power: 2 firefighting is on a distinguished road
Default usb drive problem
I have a 1GB Kingston stick that seems to work fine in every way (regardless of OS) except on my own pc .
When I insert it into one of my ports, it doesn't show in the drives listing menu. However in Disk Management but I cannot explore, format or change the drive letter. I just get an error message. I have formated on another pc and even renamed but the result is still the same. I guess it may be logged in the registry.
Do drives have some sort of embeded tag that is recognised in the registry which is blocking it's operation on my pc and cannot be removed even after formatting?
I know 1GB sticks are cheap and replacing it is the easy answer, but I have to get to the bottom. any help most appreciated. TIA
Old 14-11-2008, 05:58 PM   #2
JohnMason's Avatar
england uk city of london
Rep Power: 1 JohnMason is on a distinguished road
Default
Do other sticks work well in your pc?
I know that when you put usb devices in to your pc it stores a record locally of it. There's a program you can use to delete those records, I just can't think of the bloody name! If you still have the problem on monday PM me and i'll try to find out. :-)
Old 14-11-2008, 05:58 PM   #3
kmount's Avatar
uk
Rep Power: 34 kmount is a splendid one to beholdkmount is a splendid one to beholdkmount is a splendid one to beholdkmount is a splendid one to beholdkmount is a splendid one to beholdkmount is a splendid one to beholdkmount is a splendid one to behold
Default
Do other 1GB Kingston sticks work in your PC?
What is the error?
Old 14-11-2008, 06:03 PM   #4
uk uk kent
Default
Yes other sticks including Kingston. I even copied the data back on to another Kingston stick and that worked. It just this one stick that won't work.
Very sorry, paranoia is setting in
Old 14-11-2008, 06:05 PM   #5
uk uk kent
Default
Quote:
What is the error?
Yep! other 1GB Kingston sticks work even with my data put on them. I tried 3 BTW.
Old 14-11-2008, 06:10 PM   #6
Andrew_C's Avatar
uk uk wessex
Rep Power: 13 Andrew_C has a spectacular aura aboutAndrew_C has a spectacular aura about
Default
You don't have another drive with a letter clashing do you? I've seen that one more than once.
Old 15-11-2008, 01:58 AM   #7
uk uk kent
Default
Quote:
No drive clashing as I can add another drive and it is fine. It just seem to be this one drive. I cannot work it out. There must be a way the registry knows what usb is inserted!
Old 15-11-2008, 10:59 AM   #8
AngryTechnician's Avatar
uk
Rep Power: 4 AngryTechnician will become famous soon enough
Default
I've seen something like this before. Can you do a quick test; if you can see a drive letter in Disk Management, try opening the Command Prompt and changing to that drive letter, then see if you can execute a dir command.
Old 17-11-2008, 11:48 AM   #9
uk uk kent
Default
Quote:
I can see the drive in DM (see attached) but cannot change letter, read or format drive. Anyother PC I can do all of the above.
When I try to do any of the above on my PC, I get an error (see attached).
Old 17-11-2008, 11:53 AM   #10
OutToLunch's Avatar
Rep Power: 23 OutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of light
Default
Try zapping all previously connected USB flash drives that the PC remembers with USBDeview - View all installed/connected USB devices on your system so they're properly redetected next time you plug in...
The Following User Says Thank You to OutToLunch For This Useful Post:
firefighting (17-11-2008)
Old 17-11-2008, 11:58 AM   #11
powdarrmonkey's Avatar
uk
Rep Power: 26 powdarrmonkey is a splendid one to beholdpowdarrmonkey is a splendid one to beholdpowdarrmonkey is a splendid one to beholdpowdarrmonkey is a splendid one to beholdpowdarrmonkey is a splendid one to beholdpowdarrmonkey is a splendid one to behold
Default
Restart the logical disk management service (both of them).
The Following User Says Thank You to powdarrmonkey For This Useful Post:
Old 17-11-2008, 12:18 PM   #12
JohnMason's Avatar
Default
Quote:
Thats the one I was looking up. Just got round to finding it and it's already posted
The Following User Says Thank You to JohnMason For This Useful Post:
Old 17-11-2008, 02:55 PM   #13
uk uk kent
Default
When you say "zap", do you mean from the list display in USBDeview?
I can see the listing and the properties of the drives and what looks like a rogue entry! What ever I do, the list just seems the same.
I could use this listing and find the drive in the registry and delete from there. Is this what you mean?
Old 17-11-2008, 03:00 PM   #14
JohnMason's Avatar
Default
Personally i'd "delete" all usb sticks from there. Don't touch the root hubs and stuff (which are hidden by default), but any usb devices should just be deleted. That way they'll load up fresh next time they are plugged in.
If you have a usb mouse though, don't delete that one... Or at least remember you are deleting it... I certainly didn't make that mistake then panic when my mouse wouldn't work, honest!
Old 17-11-2008, 03:00 PM   #15
OutToLunch's Avatar
Default
Sorry, right click the device in the Device Name column and choose uninstall. Do this for all USB flash drives which have been previously connected, wouldn't recommend doing it for usb printers as some can get a bit confused afterwards when redetected.
Reply
Register now for FREE and post messages!
Username: Password: Confirm Password: E-Mail: Confirm E-Mail:
Birthday:
Image Verification
  I agree to forum rules
Thread Thread Starter Forum Replies Last Post
usb drive letter problem RabbieBurns Windows 23 01-05-2008 09:48 AM
Ghosting to USB drive. boomam How do you do....it? 2 09-04-2008 03:20 PM
USB Drive letter TechSupp How do you do....it? 9 05-03-2008 10:27 AM
USB drive is not formatted!!!! Gambit Windows 8 19-10-2007 01:41 PM
Cool looking new USB Drive Ric_ General Chat 1 24-11-2005 09:32 AM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 ©2008, Crawlability, Inc.
Copyright EduGeek.net
