Hardware Thread, Will reinstalling Windows Pro from cd bootup fix Admin lock out problem? in Technical; I have a laptop my friend gave to me which was a workstation at a Motorola campus, and my friend ...
30th August 2008, 02:43 AM #1
- Rep Power
- 0
I have a laptop my friend gave to me which was a workstation at a Motorola campus, and my friend lost the Password to the main user profile that used the workstation and made a pass for Administrator that he forgot, essentially locking himself out or anyone elset trying to log in as administrator.
So I was thinking,......
Can't I also borrow a copy of Windows Professional from my brother or someone who I know has it on CD and install it using the cd boot-up method and the Windows Professional key that's under the laptop?
IDG Tech News
30th August 2008, 06:46 AM #2
- Rep Power
- 0
M$ Licensing makes it pretty hard to just use any old XP cd. But if you can boot to a CD the odds are that Ophcrack will get you that pesky password your looking for.
30th August 2008, 06:52 PM #3
Originally Posted by
petroz
And if you can't, simply remove the harddrive from the laptop (don't worry, they pretty much all just unscrew) and put it in a 2.5" USB drive caddy (£5 from eBay) and run Ophcrack on it from a different PC.
David Hicks
30th August 2008, 10:09 PM #4 try a cotton bud swipe over the cd lens first though.
3rd September 2008, 12:34 PM #5 If you can still get into the laptop under a different log on name, you might be able to do something about it. If you go to run and type in "control userpasswords2" you may be able to change the administrator password. This does depend on you being able to still get into the laptop and having enough permissions to get to it. Another thing you could try is joining the laptop to a domain (if it has pro on it) and then resetting the local administrator password on the laptop, then you could remove it from the domain.
If you can't do either of these i would just re-install the computer - btw can't you contact the manufacturer for a reset CD? This would be totally legal and put on all the drivers/software, etc...
3rd September 2008, 05:03 PM #6
- Rep Power
- 0
you can also reset password by opening up a new notepad sheet, typing
@echo off
net administrator*
and save as a .bat file. Open the .bat file and do your thing. Of course tho, it all depends on whether I can get in or not.
3rd September 2008, 07:44 PM #7 I have used TRK to recover a lost admin p/w from a non-domain XP box... cant see why it shouldn't pull out the local admin tho.
Trinity Rescue Kit | CPR for your computer
By contink in forum Office Software
Last Post: 20th November 2008, 02:33 PM
By Scruff in forum General Chat
Last Post: 12th September 2007, 10:52 AM
By tazz in forum How do you do....it?
Last Post: 29th August 2007, 03:15 PM
By goodhead in forum Windows
Last Post: 26th February 2007, 10:22 PM
By Pear in forum Wireless Networks
Last Post: 5th January 2006, 03:27 PM
- You may not post replies
- You may not edit your posts
Forum Rules
