Results 1 to 4 of 4
Hardware Thread, Projector help... What is Monitor Re-drive? in Technical; I have just been asked a question about a projector and I'm having a Friday afternoon brain freeze. What is ...
    karlieb's Avatar
    Sep 2007
    Nottingham
    1
    16
    What is a Monitor Re-Drive?
    dhicks's Avatar
    Aug 2005
    Knightsbridge
    1,258
    236
    Quote Originally Posted by karlieb View Post
    Output port on the projector that you then connect a monitor to so you can see the same thing on both (handy for presentations where you're facing away from the screen). The better sort of projector installers provide two VGA ports on the wall, one to plug a computer into to send the signal up to the projector and the other to plug a monitor into to get the signal back again. I think, in that case, the "re-drive" is actually a VGA splitter device with a bit of powered signal boosting at the computer end of things, avoids having to run a VGA cable all the way up to the projector and a second one all the way back again.
    David Hicks
  3. Thanks to dhicks from:
    karlieb (18th July 2008)
  4. #3
    karlieb's Avatar
    Sep 2007
    Nottingham
    1
    16
    still in brain freeze mode...
    but surely you will need to re-cable all the way back down from the projector to the monitor? otherwise how will the monitor get its input?
  5. #4
    dhicks's Avatar
    Aug 2005
    Knightsbridge
    1,258
    236
    Because the wall-plug with the VGA ports in it isn't just a wall-plug, it also has a bit of circuitry in to split the VGA signal before it goes off to the projector and puts a copy out to the second VGA port for you to plug a monitor into. I think "re-drive" implies something slightly fancier than a simple two-way VGA splitter, maybe a powered signal booster of some kind to stop the signal degrading after being split, although I'm not sure about that.
    David Hicks
  1. Permissions on your simsroot/sims drive/s: drive
    By Oops_my_bad in forum MIS Systems
    Last Post: 30th August 2014, 09:41 PM
  2. Best freeware IP monitor
    By JJonas in forum Windows
    Last Post: 19th June 2008, 12:33 PM
  3. Classroom Monitor
    By speckytecky in forum Educational Software
    Last Post: 8th June 2008, 08:07 AM
  4. Monitor goes eeeeeeechhhh
    By ICT_GUY in forum Hardware
    Last Post: 15th April 2008, 09:10 AM
  5. Replies: 7
    Last Post: 8th July 2007, 09:40 PM
