Results 1 to 10 of 10
Hardware Thread, Weird monitor problem in Technical; Ok so I having been setting up some new machines today. I get to one, connect up all the gubbings ...
    sparkeh's Avatar
    May 2007
    1,298
    22
    507
    I get to one, connect up all the gubbings and switch it on. I get 'no signal' from the TFT monitor. After checking all the connections I swap it out for the TFT monitor on the machine next to it and 'no signal'.
    So then I take a known good TFT and stick it on and 'no signal'. By now I am thinking that the new machine has an issue so I hook up the TFTs back with their original machines and turn them on...both 'no signal'. Now I have three machines with no output and I am quite confused.
    So, next I rustle up an old CRT and connect that to the first machine and bingo it works. Connect the TFT up to it again and it works now?! Subsequently connecting the CRT and then the TFTs to the other machines works.
    Throughout the day these machines have displayed the 'no signal' message which is cured by connecting the CRT and then the TFT.
    Anyone have any clue what is going on 'cause I am baffled
    PeterW's Avatar
    Nov 2006
    Portsmouth
    42
    31
    What machines are they? Also what is the make model of the monitors?
    sparkeh's Avatar
    May 2007
    1,298
    22
    507
    Thanks for the reply.
    They are RM Ascend 2040 machines with DGM L-1731 monitors.
    Feb 2006
    Derbyshire
    181
    65
    Refresh rate/resolution set out of range for the new TFT? Try setting to 800x600 and 60hz before connecting, or boot in VGA mode to test...
    sparkeh's Avatar
    May 2007
    1,298
    22
    507
    Quote Originally Posted by OutToLunch View Post
    Well I thought this but the thing is they seem to work ok for a while, then you boot and get the 'no signal'. I can't see that anything has changed as when you stick on the CRT its still at 800x600 as it was before.
  6. #6
    mac_shinobi's Avatar
    Aug 2005
    3,320
    365
    bios
    any settings in the bios with regards to the graphics card and how much ram they use etc ?
    Also are these onboard graphics cards or not ?
    Do the new tft's come with manuals to tell you what they support in terms of refresh rates, resolutions etc etc ?
    Maybe try the resolution set to 1024* 768 with refresh rate of 60 + hz ?
  7. #7
    FN-GM's Avatar
    Jun 2007
    UK
    888
    12
    454
    What make of graphics do they have? A school down the road had a similar problem with onboard intel graphics.
  8. Thanks to FN-GM from:
    sparkeh (10th June 2008)
  9. #8
    Aug 2005
    3,320
    365
    Intel
    With the onboard intel graphics chipsets you are better off installing the latest drivers and using the intel utility to set the refresh rate, resolution etc as the intel util over rides the windows settings some what.
  10. Thanks to mac_shinobi from:
  11. #9
    sparkeh's Avatar
    May 2007
    1,298
    22
    507
    Thanks for the on board Intel suggestions. They do indeed have this.
    I will try the Intel utility. Thanks again.
  12. #10
    whiplash2006's Avatar
    Jun 2008
    Newcastle upon Tyne
    I would defo try the above, 90% of these prblems are down to driver issues. If the video adapter is on board it may be worth resetting the CMOS or looking at flashing the BIOS (Only do this if you really have to though!). Out dated drivers and BIOS settings caused havoc with our NEC machines, some had the CMOS reset and have worked fine since, others needed the BIOS update run, was a nightmare!
  1. Weird smartcache 2 problem.
    By K.C.Leblanc in forum Network and Classroom Management
    Last Post: 18th March 2008, 08:40 AM
  2. Weird RIS problem today..............!
    By Kyle in forum General Chat
    Last Post: 17th October 2007, 10:49 PM
  3. Weird problem
    By akatuk in forum How do you do....it?
    Last Post: 10th October 2007, 08:30 PM
  4. Promethean weird problem
    By sbutterworthtj in forum Windows
    Last Post: 19th June 2007, 09:37 PM
  5. Weird AD problem
    By SpuffMonkey in forum Windows
    Last Post: 29th March 2006, 10:57 AM
