Welcome, Register for free! or Login below:
EduGeek.net RSS Feeds Register FAQ Members Social Groups User Map Calendar Search Today's Posts Mark Forums Read
Hardware
Hardware forum sponsored by
HardwareForum Sponsored by SCL Online
For any hardware related issues, recommendations or warnings about awful equipment.
Go Back   EduGeek.net Forums > Technical > Hardware
Reply
LinkBack Thread Tools Search Thread Language
Sponsored Links
Old 21-01-2008, 11:55 AM   #1
OutToLunch's Avatar
Rep Power: 23 OutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of lightOutToLunch is a glorious beacon of light
Default Any wireless points still using a power brick + kettle lead?
Maybe an odd request this - need to upgrade a wireless link between two buildings, currently a painfully slow but reliable 11mbps. Want to upgrade to 54 or 108 gear, but the tricky part is - had a sparky sort out a hardwired kettle lead because people kept turning the bridge off... Does anyone know of/have any current gear which uses a kettle lead connection to a power brick then on to the access point? Everything new I have at the moment simply uses a transformer style plug! Rats.
Old 21-01-2008, 11:58 AM   #2
localzuk's Avatar
isle of man uk isle of man
Rep Power: 33 localzuk is a name known to alllocalzuk is a name known to alllocalzuk is a name known to alllocalzuk is a name known to alllocalzuk is a name known to alllocalzuk is a name known to all
Send a message via MSN to localzuk Send a message via Yahoo to localzuk Send a message via Skype™ to localzuk
Default
Quote:
I'm not sure about that, but if you can't locate one specifically, you could try getting hold of one of the cheap 3com PoE adapters as these use a kettle lead type connector and a PoE friendly access point.
Old 21-01-2008, 12:01 PM   #3
plexer's Avatar
uk
Rep Power: 33 plexer is a name known to allplexer is a name known to allplexer is a name known to allplexer is a name known to allplexer is a name known to allplexer is a name known to all
Default
HP420 psu are kettle plug.
Old 21-01-2008, 12:16 PM   #4
Ric_'s Avatar
uk uk lancashire
Rep Power: 44 Ric_ is a splendid one to beholdRic_ is a splendid one to beholdRic_ is a splendid one to beholdRic_ is a splendid one to beholdRic_ is a splendid one to beholdRic_ is a splendid one to beholdRic_ is a splendid one to behold
Send a message via MSN to Ric_ Send a message via Skype™ to Ric_
Default
I know my BlueSocket WAPs use kettle leads... why not use PoE though? An injector is under £20.
Old 21-01-2008, 12:23 PM   #5
plexer's Avatar
uk
Default
Injector is under £10 the 3com ones are about 6 or 7 quid each.
Old 21-01-2008, 12:36 PM   #6
ICT_GUY's Avatar
Rep Power: 16 ICT_GUY is a jewel in the roughICT_GUY is a jewel in the roughICT_GUY is a jewel in the roughICT_GUY is a jewel in the rough
Default
I tape mine up and add a notice saying do not switch off or unplug.
Gaffer tape works well.
Old 21-01-2008, 12:44 PM   #7
OutToLunch's Avatar
Default
Thanks for the suggestions so far!
You'd be surprised how well people manage to selectively ignore these, and somehow even turn off plugs covered up with bright red electrical tape and a sign saying "IF YOU TURN THIS OFF THE WHOLE OF BLOCK X LOSES NETWORK ACCESS"... Also very good at turning the directional antenna to point in the complete opposite direction...
Old 21-01-2008, 12:47 PM   #8
ricki's Avatar
uk
Rep Power: 9 ricki will become famous soon enough
Default
I know this is what what you where asking directly. But if you need to change the connection between the two building and cannot afford the fibre or a cable put between the two building.
It might be worth having a look at http://www.dabs.com/ProductView.aspx...1030&InMerch=1
There are various makers and speeds but they are a simple solution if the power fort he other building is from a close building with a network in it.
Richard
Old 21-01-2008, 01:07 PM   #9
Andrew_C's Avatar
uk uk wessex
Rep Power: 13 Andrew_C has a spectacular aura aboutAndrew_C has a spectacular aura about
Default
Quote:
Richard
Providing the sockets you choose are on the same phase, and the length of wiring between the sockets is <200m. Consider that the two buildings, even if on the same phase, may not have any shared cable until you get back to a sub-station.
Reply
Register now for FREE and post messages!
Username: Password: Confirm Password: E-Mail: Confirm E-Mail:
Birthday:
Image Verification
  I agree to forum rules
Thread Thread Starter Forum Replies Last Post
Setting up wireless access points tomscaper Networks 11 11-09-2007 08:58 AM
3COM Wireless access points - dropping network constantly Halfmad Networks 4 24-08-2007 02:37 PM
Need a Lenovo continental power lead... beeswax Hardware 4 31-07-2007 08:37 AM
Test individual access points in a dense wireless network monkey_boy How do you do....it? 8 06-02-2007 08:49 PM
Wireless Access Points kiran Hardware 17 22-10-2006 09:42 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0 ©2008, Crawlability, Inc.
Copyright EduGeek.net
