Results 1 to 5 of 5
Hardware Thread, Humax Foxsat-HDR recording & viewing problem in Technical; I bought the Humax Foxsat GB 500GB recorder in 2011. Perfect until now. I can only record 1 prog not ...
    Jul 2014
    Perfect until now.
    I can only record 1 prog not 2. And can only watch the prog I am recording.
    All other 200+ progs show a black screen with the words "No or bad signal".
    The hard disc is only 7% full. Any advice much appreciated.
    FredB.
    jinnantonnixx's Avatar
    Mar 2011
    In the Calamatorium.
    113
    2
    286
    I've had my Foxsat for years, they're the gold standard for reliability.
    But anyway, go to the setup menu (with the icon of a satellite, I think) and look at the signal strength/quality of both of the satellite inputs. You are using two satellite inputs aren't you?
    Try connecting just one input and performing a Freesat tune.
    You'll need to do a fresh Freesat tune every time you change something on the satellite inputs. (It takes less than a minute)
    Long shot, but maybe one cable has gone bad, and a fresh Freesat tune will pick up the missing channels using the one good cable. Worth a shot.
    Jan 2013
    20
    6
    Sounds like your second connection to the sat has been damaged / faulty. Could check cables if you can and also connection to the lmb.
    Jul 2014
    Did the retune with each input in turn as you suggested. Both OK. So reconnected both & everything works. Result! Bad/loose connection?
    Either way - very many thanks.
    Fred
    Jul 2014
    You were right - connection problem. See reply to jinnantonixx. Many thanks for 'instant' replies to both of you.
    Fred
  1. Attention Humax Foxsat HDR owners
    By jinnantonnixx in forum AV and Multimedia Related
    Last Post: 22nd February 2012, 02:47 PM
  2. TTS Easi-View problems
    By sparkeh in forum AV and Multimedia Related
    Last Post: 26th January 2012, 12:41 PM
  3. Humax Foxsat HDR (Freesat) owners look at this....
    Last Post: 13th September 2011, 08:58 AM
  4. Explorer view problem in WSS
    By trinityswift in forum Windows Server 2008
    Last Post: 10th June 2011, 10:41 AM
  5. Humax Foxsat HD Receiver
    By laserblazer in forum General Chat
    Last Post: 11th February 2011, 11:01 AM
