Results 1 to 2 of 2
Hardware Thread, USB Power Surge in Technical; I just put a PCI-e USB3 card that I got on Ebay into my system. The supplied drivers didn't work, ...
    Sep 2007
    UK
    1,462
    647
    USB Power Surge
    I just put a PCI-e USB3 card that I got on Ebay into my system. The supplied drivers didn't work, so I found some for another card that uses the same NEC chip. This installed ok and device manager is happy but I got "Power Surge on Hub" message, even with no device plugged in. The board has a connector the same as on floppy drives. The psu lead is not long enough to reach the card, so I can't try it. It's a 1 lane card, so is that why it isn't getting sufficient power? If I can extend the floppy power lead, should that fix it?
    plexer's Avatar
    Dec 2005
    Norfolk
    756
    438
    I expect that yes that card will need the extra power connector to be able to operate correctly.
  3. Thanks to plexer from:
    laserblazer (15th June 2014)
  1. Trying not to panic.... USB power surge error
    By Little-Miss in forum Hardware
    Last Post: 30th August 2011, 02:33 PM
  2. Wireless Bridge - Preferably USB powered
    By Edu-IT in forum Hardware
    Last Post: 30th December 2010, 09:01 PM
  3. nintendo dsi usb power connector
    By alextreadwell in forum Netbooks, PDA and Phones
    Last Post: 26th February 2010, 11:36 AM
  4. Printers not working after power surge.
    By big_nath in forum Hardware
    Last Post: 19th March 2009, 06:25 PM
