Results 1 to 5 of 5
Hardware Thread, Strange Audio Problem in Technical; Had this issue for a while and initially thought it was due to the sound files being played but... when ...
    TechSupp's Avatar
    Mar 2007
    South Yorkshire
    295
    40
    Had this issue for a while and initially thought it was due to the sound files being played but... when headphones are plugged in I can hear a 'bing' when I alter the sound level and when I play some of the sample music audio in media player but not some of the sound effects etc when using the web based Education City or some of the other programs. I thought this was down to the media type being played but...accidentally found that if I move the audio plug out of the socked about an 1'8" I hear the Education City music perfectly and they work as normal. Now that makes you think its the audio jack or socket? but why can I hear music played via media player etc when its fully pushed in and not in Education City for example but pull it out slightly I can hear both? confused to say the least!
    I now have this at two schools, different PC's both RealTek bith same type of headphone (The Robust ones from Hills Components)
    Any ideas anyone?
    GeekyPete's Avatar
    Mar 2013
    In a cold dark server room.
    23
    26
    You get the same thing if you use headphones off some mobile phones. I get it off my Beats Audio Dr.Dre Monsters. A standard 3.5mm stereo jack has three connectors. These are the shiney metal bands separated by two black (insulating) bands. Check that the headphones you are using have exactly this configuration. One black band and it's mono. 3 or more bands and there is extra functionality. This can be Volume, Mute, ffwd, rwd etc. As you pull the plug out it will contact with the correct leaf spring connectors in the socket and the sound becomes correct. Some of the effects can be very weird because some sounds get cancelled out entirely where others seem louder. This is through a combination of stereo imagaing as the connections are made and constructive and destructive phasing.
    If it is this configuration make sure you are plugging it into a standard stereo socket. Not SPIF or similar.
    (now I sound like a bad episode of star trek)
    TechSupp's Avatar
    Mar 2007
    South Yorkshire
    295
    40
    Just checked and they are bog standard three part jacks, left, right, earth. But why not on all PC's? Just tried another pair of h'phones and they worked fine! Will do some more testing when I find another set tbat play up.
    mac_shinobi's Avatar
    Aug 2005
    3,239
    363
    Maybe get USB headphones and it won't rely on making contact with the relevant contacts in the 3.5mm jack
    GeekyPete's Avatar
    Mar 2013
    23
    26
    Could just be faulty headphones, what happens when you plug them into other computers or your phone?
  1. Strange Excel Problem
    By Jon in forum Windows
    Last Post: 14th July 2011, 04:55 PM
  2. Strange Email Problem
    By richard in forum Windows
    Last Post: 15th June 2007, 06:58 AM
  3. Strange Word problem
    Last Post: 21st February 2006, 12:47 PM
  4. Strange HD Problem on Debian machine
    By crc-ict in forum *nix
    Last Post: 27th January 2006, 08:43 PM
  5. Strange Network Problem this Morning
    By Roger in forum Windows
    Last Post: 12th September 2005, 11:01 AM
