Results 1 to 2 of 2
Hardware Thread, Epson Projector - VPL-ES2 (will not turn on when power has been left off for a while) in Technical; Hi All, Don't know if this post is best here or AV thread.... (MOD please move if you feel it ...
    Koldov's Avatar
    May 2011
    Bedfordshire
    101
    39
    Hi All,
    Don't know if this post is best here or AV thread.... (MOD please move if you feel it appropriate).
    After being switched off at the socket over the holidays, a few of these projectors failed to switch back on at the start of term.
    However, after a couple of hours they miraculously come to life.
    I have noticed this has become the norm for a few of these projectors now, when they are switched of at the wall socket they will refuse to power on unless they are left with power on for a while.
    I think this might be power supply related...
    Any ideas?
    Kol.
    Sep 2013
    Shrewsbury UK
    2
    I've seen this issue quite a lot over the years with switch mode power supplies in various computers and related devices. Components can fail over time with heat and age and once cooled down do not perform. Commonly electrolytic capacitors dry out and fail in power supplies often indicated by bulging or splitting tops on their metal case. Other components too may suffer with age and heat. If totally dead for a while I would suspect this sort of failure is developing with the main power supply. Probably a common failure for that make if a number the same are suffering.
    A range of early Hitachi engined projectors we had also used to suffer similar with the lamp ballast unit which provides high voltage to strike the lamp. Once disconnected from mains for a while the projector would power up but the lamp would no longer light. Sometimes recovering after being powered on for a while.
    regards Richard.
  1. Sanyo PLC-XE40 Multiverse Projector does not turn on
    By Vierkantdel in forum AV and Multimedia Related
    Last Post: 16th April 2013, 11:59 AM
  2. [SIMS] Solus3 Agent will not install on server [Solved]
    By ianswalker in forum MIS Systems
    Last Post: 22nd December 2011, 01:59 PM
  3. mac will not log on
    By robertsenior in forum Mac
    Last Post: 24th September 2010, 05:55 PM
  4. SIMS will not load on Server 2008 64bit
    By KWestos in forum MIS Systems
    Last Post: 8th October 2009, 08:50 PM
  5. A XP SP2 Laptop will not log on offline
    By redsnappa in forum Windows
    Last Post: 14th November 2006, 12:05 PM
