Results 1 to 3 of 3
Hardware Thread, NIC Teaming Problem... Help!!??!!! in Technical; Hi all, Got a recently rebuilt file server - domestic mobo, Adaptec 3805 RAID card - 12 TB, does the ...
    mikkydoos's Avatar
    Jan 2009
    Jupiter and Saturn
    53
    16
    Angry NIC Teaming Problem... Help!!??!!!
    Hi all,
    Got a recently rebuilt file server - domestic mobo, Adaptec 3805 RAID card - 12 TB, does the job.
    Just put in a Startech ST1000SPEX42 quad port network card to improve network throughput/failover.
    Card has 4 X NIC interfaces
    Chipset - Realtek RTL8111E
    Server is running Windows Server 2008 R2
    Using Realtek Network Diagnostic Utility to perform the teaming of the 4 interfaces
    Card is IEEE802.3x compliant for LACP
    Connecting to a Netgear GSM7224 L2 managed switch compliant for LACP
    Teamed all 4 ports to one virtual adapter, set the IP etc works fine. No VLANs nothing special on the LAN.
    Now... (please help!)...
    Works fine with 1 cable connected - Windows reports 1Gb connection
    Works fine with 2 cables connected - Windows reports 2Gb connection
    ... Put a third or fourth cable in..... virtual adapter disconnects, 'No network cable connected', no connection.
    Disabled (and tried unplugging - same result) 2 of the NIC interfaces - connected again on its own.
    WTF?
    Switch config? or cr@ppy drivers / Realtek utility?? Is this a 2/2 card (doubt it) - Startech useless, Realtek - forget it.
    Driving me nuts.
    Just done an AD x 2 migration from 2003 to 2012, new VMWare setup, monster server, no hitches at all - 2 (short) days . This ones got my goat....
    Cheers in advance,
    Mikky ; ) Have good hols ; )
    mrbios's Avatar
    Jun 2007
    Stroud, Gloucestershire
    368
    101
    realtek card for a server? Wouldn't be surprised if the cheapo junk card is the issue to be honest. Get yourself an Intel quad port card instead, regardless of whether its the cause.
    mikkydoos's Avatar
    Jan 2009
    Jupiter and Saturn
    53
    16
    Would've done if we could have afforded it.
  1. OWA Authentication Problems HELP!!
    By mmoseley in forum Wireless Networks
    Last Post: 21st September 2008, 06:02 PM
  2. CC3 - Printers - Strange Problem - HELP
    By vlan2 in forum Network and Classroom Management
    Last Post: 10th August 2008, 07:49 AM
  3. OWA problem!!! help!
    By kevin in forum Windows
    Last Post: 31st March 2007, 07:19 PM
  4. IIS 6 Problem - HELP
    By Nij.UK in forum Windows
    Last Post: 7th February 2007, 12:01 PM
  5. DHCP problem HELP!!!!
    By wesleyw in forum Windows
    Last Post: 27th July 2006, 02:33 PM
Tags for this Thread
