Results 1 to 3 of 3
Hardware Thread, Front audio ports - PCI sound card in Technical; We bought a load of Stone machines including some 'high specification' towers which included both a dedicated Gfx (ATI) and ...
    Jan 2007
    8
    21
    We bought a load of Stone machines including some 'high specification' towers which included both a dedicated Gfx (ATI) and Sound (Creative) card.
    The problem is the students want to use the front audio ports for their projects and suddenly the back of a PC is too dangerous!
    Will it just be a internal cable that I could possibly attach to the Creative sound card? I did try enabling on board sound but then you need to install the drivers etc and you can't use both onboard and PCI sound, it has to be one or the other!
    cheers
    PeterW's Avatar
    Nov 2006
    Portsmouth
    42
    30
    Re: Front audio ports - PCI sound card
    Which creative soundcards are they? some of the newer ones have a standard HD Audio connection on them meaning you could use the case front ports. Otherwise you would be looking at a different solution like extension cable or buying front bay ports that come out of the back of the machine and connect to the sound card.
    Jan 2007
    8
    21
    They are Creative Labs Soundblaster Audigy SE 7.1 sound cards, and the motherboard is Intel D945GCNL.
  1. Which sound card for music technology?
    By meastaugh1 in forum Hardware
    Last Post: 10th February 2008, 11:31 PM
  2. iptables multiple ports
    By Jackd in forum *nix
    Last Post: 23rd December 2007, 10:19 PM
  3. USB Ports asking for Admin Account
    By Psymon in forum Windows
    Last Post: 14th October 2007, 10:49 PM
  4. Listening Ports
    By Samson in forum *nix
    Last Post: 2nd April 2007, 01:34 PM
  5. wsus default ports
    By russdev in forum Windows
    Last Post: 15th November 2005, 11:29 AM
