Hardware Thread, HP ProCurve 5406zl Not Booting After Power Cut in Technical; Our core switch is not booting after we had a power cut this afternoon. When power was restored I found ...
11th February 2013, 09:52 PM #1 HP ProCurve 5406zl Not Booting After Power Cut
Our core switch is not booting after we had a power cut this afternoon. When power was restored I found that the 'Fault' LED [below the power LED] and the the DIM LED [on the console] were both blinking orange about once a second.
I am waiting for HP to call me back but if anyone could point me in the right direction as to how to solve this before HP get back that would be great.
Thanks.
IDG Tech News
11th February 2013, 10:13 PM #2 Take one module out at a time and try turning it on. If its not one of the main modules it could half borked the management card
Thanks to glennda from:
DaveP (11th February 2013)
11th February 2013, 10:15 PM #3 Have you tried plugging into the console port? Might throw some light onto it.
Thanks to FN-GM from:
11th February 2013, 10:20 PM #4
Originally Posted by
glennda
FN-GM
Thanks both. These are both ideas that I had not considered [I am not familiar with the switch as it has just sat there and done its job since being installed] Actually I am hoping that the problem is not too serious as it this switch holds our VLan configuration and so without it we are dead in the water.
11th February 2013, 10:25 PM #5 If had my old one crash a couple of times randomly. I guess you have already tried the basic power cycle.
On the management card there is a rom stick which requires flashing if the management as borked itself, although it should have 2 images on itself to roll back if the first is unusable.
11th February 2013, 10:30 PM #6
glennda
If had my old one crash a couple of times randomly. I guess you have already tried the basic power cycle....
Yes. Tried the power cycle twice. Same result.
glennda
...On the management card there is a rom stick which requires flashing if the management as borked itself, although it should have 2 images on itself to roll back if the first is unusable.
Not sure how to do all that. I guess HP will be able to talk me through it? Will I need any hardware to do this? [a specific type of cable etc]
Thanks.
11th February 2013, 10:35 PM #7 You might need a new management module, we had to have a new one a few months ago, similar problem
Thanks to pritchardavid from:
11th February 2013, 10:39 PM #8 Thanks. Looks like I have my hands full tomorrow.
Night all.
11th February 2013, 10:56 PM #9 Maybe you should look at getting a second core switch? I assume you have redundancies in your servers? Seems a waste if you don't have it in the network
12th February 2013, 08:57 AM #10 Any news Dave?
Console port will hopefully throw some light.
Else take out all cards and reseat, and if that does not work take out all the line cards and restart.
Any POE cards? it may bee that the PSU's are over subscribed due to a PSU failure.
Rob
12th February 2013, 09:06 AM #11
- Rep Power
- 11
Had the same problem years ago...
Agree with most of the posts above - take all cards out and reboot the switch. If the switch boots properly, replace the cards one by one, rebooting the switch with each card you put in.
12th February 2013, 09:09 AM #12 BTW you can backup the HP Procurve's configuration to a text file via tftp or SSH scp.
TFTP:
Code:
copy run tftp 10.1.1.10 config1.cfg
SSH (from a client PC):
Code:
pscp -scp -l USERNAME -pw PASSWORD -2 192.168.100.1:cfg/running-config c:\switch.cfg
Assuming you have TFTP/SSH file transfer enabled on your switch (which you should).
12th February 2013, 09:10 AM #13
Geoff
TFTP:
Code:
Code:
you can also download it from the web-interface.
12th February 2013, 09:17 AM #14 Just for the future is your core switch on a UPS? Ours is (simlar model) after we got bored with the length of time it takes to start up after a powercut
12th February 2013, 09:29 AM #15
glennda
The web interface is bloody awful and I'd suggest you avoid using it where ever possible.
By jack0w in forum O/S Deployment
Last Post: 28th July 2009, 01:11 PM
By big_nath in forum Hardware
Last Post: 19th March 2009, 05:25 PM
By flashsnaps in forum Hardware
Last Post: 28th January 2008, 05:16 PM
By CM786 in forum Windows
Last Post: 14th December 2006, 11:43 AM
Last Post: 28th June 2006, 06:52 PM
- You may not post replies
- You may not edit your posts
Forum Rules
