Results 1 to 9 of 9
Hardware Thread, Need help choosing a DC to AC converter for solar project in Technical; Hi, I have a solar panel connected to a car battery but need this to give 240v but have found ...
    Apr 2010
    83
    84
    I have a solar panel connected to a car battery but need this to give 240v but have found different types of converters to choose from.
    I would like to be able to power a small radio, recharge my phone / laptop (not all at the same time)
    Some converters or is it inverters? have sine wave and some have modified sine wave. I assume some kind of sine wave is best rather than square wave but not sure which.
    What watts would I need? Thinking about 300w
    Does this look good? http://www.amazon.co.uk/PURE-SINE-WA...0228772&sr=8-1
    Thanks for any help.
    unixman_again's Avatar
    Nov 2011
    30
    136
    In general sine wave is much better for your equipment than square wave. I'd recommend that you talk to the people at Maplins or similar electronics store; they should know about inverters. Here is a good looking one: 600W 12V Inverter
    Dos_Box's Avatar
    Jun 2005
    Preston, Lancashire
    605
    23
    632
    Moving to Hardware forum.
    Apr 2010
    83
    84
    Is a sine wave and a modified sine wave the same thing?
    I find Maplins useless in my area for tech info.
    Oaktech's Avatar
    Jul 2011
    Bournemouth
    776
    260
    a sine wave is actual gently undualting wave, which is actually quite difficult to 'make'. A modified sine wave is an approximation of a sine wave made up of increasing/decreasing amplitude square waves, which is much easier (cheaper) to make, but if your gear is in any way sensitive it will, over time, bork it. True sine wave is the way forward.
  6. #6
    Nov 2011
    30
    136
    Modified sine waves and sine waves are different. Have a look here Power inverter for a good explaination. If the staff at your local Maplins are useless (like you I've found most are) talk to their phone line. I always do it I want info on something. Having done that, I go to the shop and get it.
  7. #7
    May 2009
    273
    331
    Quote Originally Posted by edutech4schools View Post
    300w would be find for a radio or device charger. It will probably be a bit of a waste as both will run off wall-wart type convertors no doubt producing a DC voltage somewhere between 5-12 volts and neither will be particularly power hungry. So you will be going from 12v DC -> 240v AC back to 3-12 v DC. If you know the inputs of the devices, you could build a 780<N> based regulator for about 50p.
    ETA - I wouldn't worry too much about modified sine wave. Most consumer devices use AC->DC supplies which are perfectly capable of dealing with a mucky supply.
  8. #8
    Apr 2010
    83
    84
    What is this? I have done a google but the wart converters seem to require an AC input. Am I looking at the correct devices?
    My solar panel comes with a female cig lighter. Not wanting to blow up by expensive Samy phone would I be ok to connect straight to the female cig lighter? presumably this is no different to charging in a car or should I go through a 240v converter and use the normal 3 pin plug?
  9. #9
    May 2009
    273
    331
    [QUOTE=edutech4schools;884742]What is this? I have done a google but the wart converters seem to require an AC input. Am I looking at the correct devices?
    [quote]
    Yes. Walwarts usually go from 240v AC to some small DC voltage.
    If your phone comes with a car cigarette plug charger, then you will be OK to plug that into the solar panel.
  1. Replies: 8
    Last Post: 24th January 2011, 10:41 AM
  2. Need help allowing Dameware to connect through ISA 2004
    By GlennT in forum Wireless Networks
    Last Post: 27th September 2007, 07:51 AM
  3. Replies: 1
    Last Post: 8th June 2007, 08:43 PM
  4. Need help getting to grips with subnetting
    By Kyle in forum Wireless Networks
    Last Post: 3rd April 2007, 11:57 AM
  5. Need help to finsih script?
    By tosca925 in forum Scripts
    Last Post: 1st November 2006, 11:08 PM
