Results 1 to 4 of 4
Hardware Thread, Viglan Pc Power Problems in Technical; Hi Everyone, This is my first post to this forum so please bear with me. My friend gave me a ...
    Jul 2007
    kidderminster
    Hi Everyone,
    My friend gave me a computer which he bought some time ago, he plugged in in some months later to find it never worked. I have brought it home to try and fix it for him but i'm a little stuck and could do with being pointed in the right direction.
    Once plugged in to the mains the pc will not power up at all. The PSU has been changed and i know this one works as it's been swapped from a working pc. The green power light comes on inside the pc which is part of the motherboard. I have tried changing the switch and this also never worked, i'm unsure as the correct switch positions for the power switch located on the motherboard and have tried numerous combinations again with a power switch from a working computer.
    The motherboard is an Intel D850MV
    Does anyone have any ideas what the problem may be as it's very frusrating.
    Kind Regards
    Mark Swan
    PeterW's Avatar
    Nov 2006
    Portsmouth
    42
    32
    Re: Viglan Pc Power Problems
    Check the technical docs here this shows the location of the front panel headers and pin outs. Just to be sure there is not a problem with the power switch when you find the correct pins short them with a screw driver.
    Also with the new psu do you have all three power connections going to the board? Or just the 20 Pin atx and 4 Pin atx 12V?
    Good Luck!
    Jul 2007
    kidderminster
    Hi there,
    Thanks for the reply, there are only 2 power leads to the motherboard
    Mark
    ChrisH's Avatar
    Jun 2005
    East Lancs
    123
    108
    Moving to hardware.
  1. NEC Power Supply Problems
    By TechSupp in forum Hardware
    Last Post: 2nd October 2007, 09:27 AM
  2. Power Over Ethernet
    By timbo343 in forum Wireless Networks
    Last Post: 20th May 2007, 09:58 PM
  3. power edge 830 RAM
    By mac_shinobi in forum Hardware
    Last Post: 19th April 2007, 02:43 PM
