Results 1 to 5 of 5
Hardware Thread, Need help with an APC UPS in Technical; Hi, I recently bought an APC back UPS for my PC. Here is the model https://www.apc.com/resource/include...ase_sku=BR1500 After plugging my computer ...
    Sep 2012
    2
    After plugging my computer into it and testing it with both positive results I decided to install the disc for it. When I clicked run an error popped up which said the following:
    The installer is unable to locate a supported APC backup battery connected to your computer. Please check your USB connections and try again.
    Now it's connected to my computer and provides power if the electricity goes out but this installer is claiming otherwise. Any help please? Btw, the APC site didn't help at all when I checked there.
    Thanks,
    plexer's Avatar
    Dec 2005
    Norfolk
    587
    397
    Have you connected the usb cable between the ups and your pc?
    Without a data connection between the 2 the software won't be able to see the ups, power connection alone is not sufficient.
  3. 2 Thanks to plexer:
    rotwfighter (16th September 2012), wizzard (15th September 2012)
  4. #3
    Sep 2012
    2
    Quote Originally Posted by plexer View Post
    Oh, crap... I feel like an idiot now, thanks a lot for that, I'll try it now.
  5. #4
    Sep 2012
    2
    ok, working now, thanks a lot :P
  6. #5
    plexer's Avatar
    Dec 2005
    Norfolk
    587
    397
    Not a problem, there should be a thank post button if you feel like using it
  7. Thanks to plexer from:
  1. Need help with this damn "job evaluation"..
    By Oops_my_bad in forum General Chat
    Last Post: 4th May 2008, 07:26 PM
  2. need help with wsus 3.0 urgent
    By goodhead in forum Windows
    Last Post: 2nd October 2007, 10:42 AM
  3. Replies: 1
    Last Post: 11th March 2007, 06:56 PM
  4. need help with few A+ core questions
    By projector1 in forum General Chat
    Last Post: 26th February 2007, 12:08 PM
  5. A Few Things I Need Help With
    By Pear in forum Windows
    Last Post: 13th October 2005, 07:42 AM
